modulelist:4-in-1_module [2016/12/11 13:38] Arnold |
- | Read post #55157 by Vlad_vy in the following thread for guidance on soldering to various Devo radios, along with the associated hardware.ini file settings. Here's the link: | + | Read post #55157 by Vlad_vy [[https://www.deviationtx.com/forum/7-development/5434-3in1-4in1-rf-module?start=940#55157]] for guidance on soldering to various controllers, along with the associated hardware.ini file settings for enabling the modules in Deviation. **Note: You must __NOT__ be logged in to the Forum for the above link to work properly. |
- | http://www.deviationtx.com/forum/7-development/5434-3in1-4in1-rf-module?start=940#55157 | + | ** |
modulelist/4-in-1_module.1481492312.txt.gz (10602 views) · Last modified: 2016/12/11 13:38 by Arnold
