modulelist:4-in-1_module [2017/01/16 15:20] Arnold |
| Line 3: | Line 3: | ||
| By replacing the original CYRF module in your Devo with this module, you can get the full complement of modules that your Devo (with Deviation firmware installed) is capable of supporting: A7105, CC2500, NRF24L01, and CYRF6936 RF modules, all using the original antenna on your Devo. | By replacing the original CYRF module in your Devo with this module, you can get the full complement of modules that your Devo (with Deviation firmware installed) is capable of supporting: A7105, CC2500, NRF24L01, and CYRF6936 RF modules, all using the original antenna on your Devo. | ||
| - | Shown below is the Devo 4-in-1 Module with the Devo daughter board, made specifically for the Devo line of radios. Once you plug it in to the existing socket (on Devos other than the 7E), only 3 more connections are needed from the board to the radio; one each for enabling the A7105, CC2500, and NRF24L01 components that are under the metal shield. Click on an image for a detailed close-up view. | + | Shown below is the Devo 4-in-1 Module with the Devo daughter board, made specifically for the Devo line of radios. Once you plug it in to the existing socket (on Devos other than the 7E), only 3 more connections are needed from the board to the controller; one each for enabling the A7105, CC2500, and NRF24L01 components that are under the metal shield. Click on an image for a detailed close-up view. |
| - | Read post #55157 by Vlad_vy [[http://www.deviationtx.com/forum/7-development/5434-3in1-4in1-rf-module?start=940#55157]] for guidance on soldering to various radios, along with the associated hardware.ini file settings for enabling the modules in Deviation. **Note: You must __NOT__ be logged in to the Forum for the above link to work properly. | + | Read post #55157 by Vlad_vy [[https://www.deviationtx.com/forum/7-development/5434-3in1-4in1-rf-module?start=940#55157]] for guidance on soldering to various controllers, along with the associated hardware.ini file settings for enabling the modules in Deviation. **Note: You must __NOT__ be logged in to the Forum for the above link to work properly. |
| {{ :modulelist:20161104_233144.jpg?direct&300 |}} | {{ :modulelist:20161104_233144.jpg?direct&300 |}} | ||
| {{ :modulelist:20161104_233158.jpg?direct&300 |}} | {{ :modulelist:20161104_233158.jpg?direct&300 |}} | ||
modulelist/4-in-1_module.1484608814.txt.gz (8310 views) · Last modified: 2017/01/16 15:20 by Arnold
