modulelist
modulelist [2016/04/14 19:01] PhracturedBlue |
modulelist [2016/11/24 21:07] Arnold [Modules] |
Line 15: | Line 16: | ||
- | | [[modulelist:cc2500#skyartec|CC2500 Skyartec]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | | + | | [[modulelist:cc2500#skyartec|CC2500 Skyartec]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | |
- | | [[modulelist:cc2500#aliexpress|CC2500 Aliexpress]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | + | | [[modulelist:cc2500#aliexpress|CC2500 Aliexpress]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** |
- | | [[modulelist:cc2500#xl2500_ebay|XL2500]] | 2 | 1 | 5 | 7 | 6 | 4 | Connect 3->10 and 8->9 **(*)** | | + | | [[modulelist:cc2500#xl2500_ebay|XL2500]] | 2 | 1 | 5 | 7 | 6 | 4 | Connect 3->10 and 8->9 **(*)** | |
- | | [[modulelist:cc2500#aliexpress-nopa|CC2500 NoPA]] | 2 | 1 | 4 | 3 | 5 | 8 | | + | | [[modulelist:cc2500#aliexpress-nopa|CC2500 NoPA]] | 2 | 1 | 4 | 3 | 5 | 8 | |
- | | [[modulelist:cc2500#small-nopa|CC2500 Small]] | 2 | 1 | 4 | 3 | 5 | 8 | | + | | [[modulelist:cc2500#small-nopa|CC2500 Small]] | 2 | 1 | 4 | 3 | 5 | 8 | |
- | | [[modulelist:nrf24l01#ufl_antenna|NRF24L01-UFL]] | 2 | 1 | 5 | 6 | 7 | 4 | Connect 3->2 | | + | | [[modulelist:nrf24l01#ufl_antenna|NRF24L01-UFL]] | 2 | 1 | 5 | 6 | 7 | 4 | Connect 3->2 | |
- | | [[modulelist:nrf24l01#xl24l01|XL24L01-D03]] | 2 | 1 | 5 | 6 | 7 | 4 | Connect 3->2 | | + | | [[modulelist:nrf24l01#xl24l01|XL24L01-D03]] | 2 | 1 | 5 | 6 | 7 | 4 | Connect 3->2 | |
- | | [[modulelist:a7105#xl7105-d03|XL7105-D03]] | 1 | 3 | 4 | 5 | -- | 2 | Connect 6->9 and 7->8 **(*)** | | + | | [[modulelist:a7105#xl7105-d03|XL7105-D03]] | 1 | 3 | 4 | 5 | -- | 2 | Connect 6->9 and 7->8 **(*)** | |
- | | [[modulelist:a7105#a7105-v911|A7105-V911]] | 6 | 5 | 2 | 3 | -- | 1 | | + | | [[modulelist:a7105#a7105-v911|A7105-V911]] | 6 | 5 | 2 | 3 | -- | 1 | |
- | | [[modulelist:a7105#a7105-xeida|A7105-Xeida]] | 6 | 5 | 2 | 3 | -- | 1 | | + | | [[modulelist:a7105#a7105-xeida|A7105-Xeida]] | 6 | 5 | 2 | 3 | -- | 1 | |
- | | [[modulelist:a7105#xl7105-sy|XL7105-SY]] | 2 | 3 | 6 | 7 | -- | 5 | | + | | [[modulelist:a7105#xl7105-sy|XL7105-SY]] | 2 | 3 | 6 | 7 | -- | 5 | |
- | | [[modulelist:cyrf6936#devo|CYRF6936-DEVO]] | 1(5V) | 5 | 4 | 8 | 10 | 2 | Connect 9->5 | | + | | [[modulelist:cyrf6936#devo|CYRF6936-DEVO]] | 1(5V) | 5 | 4 | 8 | 10 | 2 | Connect 9->5 | |
- | | [[modulelist:cyrf6936#awa24s|CYRF6936-AWA24S]] | 2 | 1 | 7 | 5 | 8 | 6 | Connect 10->11->2 and 3->12 **(*)** | | + | | [[modulelist:cyrf6936#awa24s|CYRF6936-AWA24S]] | 2 | 1 | 7 | 5 | 8 | 6 | Connect 10->11->2 and 3->12 **(*)** | |
- | | [[modulelist:cyrf6936#buychina|CYRF6936-BuyChina]] | 10 | 9 | 2 | 4 | 5 | 1 | Connect 7->11 and 8->12 **(*)** | | + | | [[modulelist:cyrf6936#buychina|CYRF6936-BuyChina]] | 10 | 9 | 2 | 4 | 5 | 1 | Connect 7->11 and 8->12 **(*)** | |
- | | [[modulelist:multimod#multimod_v12_v13|MultMod v1.2/1.3]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes Below** | | + | | [[modulelist:multimod#multimod_v12_v13|MultMod v1.2/1.3]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes On Module Page** | |
- | | [[modulelist:multimod#multimod_v14|MultiMod v1.4]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes Below** | | + | | [[modulelist:multimod#multimod_v14|MultiMod v1.4]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes On Module Page** | |
+ | | [[modulelist:3-in-1 module#3-in-1|3-in-1 Module]] | X | X | X | X | X | X | **See Notes On Module Page** | | ||
+ | | [[modulelist:4-in-1 module#4-in-1|4-in-1 Module]] | _ | _ | _ | _ | _ | _ | **See Notes On Module Page** | |
modulelist.txt (30195 views) · Last modified: 2016/12/13 15:33 by Arnold
