modulelist
modulelist [2016/03/29 10:12]
FDR [Modules]
modulelist [2016/12/13 15:33] (current)
Arnold
Line 1: Line 1:
 ====== Supported modules ====== ====== Supported modules ======
 ===== Pin Ordering ===== ===== Pin Ordering =====
 Regardless of how the modules may have their pin-order listed on their data-sheets,​ this guide uses the following pin ordering (//Except for the Multi-Module-See Below//) Regardless of how the modules may have their pin-order listed on their data-sheets,​ this guide uses the following pin ordering (//Except for the Multi-Module-See Below//)
Line 15: Line 16:
 (*) - Denotes that alternate connections are required for Deviation 4.0.1 or below. See Module section below for more info (*) - Denotes that alternate connections are required for Deviation 4.0.1 or below. See Module section below for more info
-Module ​       ^ Power ^ Ground ^ SCK ^ MOSI ^ MISO ^ CSN ^ Notes ^ +^  ​Module ​       ^  Power   Ground ​  SCK   MOSI   MISO   CSN   Notes
-| | {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​4168848131-White.png}} | {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​2083651818-Black.png}} | {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​1221698502-Yellow.png}} | {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​132304774-Purple.png}} | {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​4056447960-LightGrey.png}} | {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​883382089-LightBlue.png}} | +| |  {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​4168848131-White.png}} ​  {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​2083651818-Black.png}} ​  {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​1221698502-Yellow.png}} ​  {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​132304774-Purple.png}} ​  {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​4056447960-LightGrey.png}} ​  {{https://​bitbucket.org/​repo/​Ag6rxe/​images/​883382089-LightBlue.png}} ​ |
-| [[ModuleList#markdown-header-skyartec-httpwwwskyarteccomproductshowasparticleid1977|CC2500 Skyartec]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | +| [[modulelist:​cc2500#​skyartec|CC2500 Skyartec]] |             | Connect 5->10 and 7->9 **(*)** |
-| [[ModuleList#markdown-header-aliexpress-httpwwwaliexpresscomitemcc2500-pa-lna-wireless-module-far-distance-2-4g359941652html|CC2500 Aliexpress]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** +| [[modulelist:​cc2500#​aliexpress|CC2500 Aliexpress]] |             | Connect 5->10 and 7->9 **(*)**
-| [XL2500](ModuleList#​markdown-header-xl2500-ebay-httpwwwebaycomitm110983783515) ​| 2 | 1 | 5 | 7 | 6 | 4 | Connect 3->10 and 8->9 **(*)** | +| [[modulelist:​cc2500#​xl2500_ebay|XL2500]            | Connect 3->10 and 8->9 **(*)** |
-| [CC2500 NoPA](ModuleList#markdown-header-aliexpress-nopa-httpwwwaliexpresscomitem1-pcs-cc2500-wireless-module-small-size-2-4ghz-wireless-transceiver-module-free-shipping-dropshipping1566632579html) ​| 2 | 1 | 4 | 3 | 5 | 8 | +| [[modulelist:​cc2500#​aliexpress-nopa|CC2500 NoPA]] |  ​
-| [CC2500 Small](ModuleList#markdown-header-small-nopa-httpwwwebaycomitm1-8-3-6v-cc2500-ic-wireless-rf-transceiver-2-4g-2400mhz-module-ism-spi-demo-code-280943872644) ​| 2 | 1 | 4 | 3 | 5 | 8 | +| [[modulelist:​cc2500#​small-nopa|CC2500 Small]] |  ​
-| [NRF24L01-UFL](ModuleList#​markdown-header-ufl-antenna-httpwwwebaycomitm400611170500) ​| 2 | 1 | 5 | 6 | 7 | 4 | Connect 3->2 | +| [[modulelist:​nrf24l01#​ufl_antenna|NRF24L01-UFL]            | Connect 3->2 |
-| [XL24L01-D03](ModuleList#​markdown-header-xl24l01-httpwwwebaycomitm160763860120) ​| 2 | 1 | 5 | 6 | 7 | 4 | Connect 3->2 | +| [[modulelist:​nrf24l01#​xl24l01|XL24L01-D03]            | Connect 3->2 |
-| [XL7105-D03](ModuleList#markdown-header-xl7105-d03-httpwwwebaycomitm181091377178) ​| 1 | 3 | 4 | 5 | -- | 2 | Connect 6->9 and 7->8 **(*)** | +| [[modulelist:​a7105#xl7105-d03|XL7105-D03]]          --    | Connect 6->9 and 7->8 **(*)** |
-| [A7105-V911](ModuleList#markdown-header-v911-v911moduleremoval) ​| 6 | 5 | 2 | 3 | -- | 1 | +| [[modulelist:​a7105#a7105-v911|A7105-V911]] ​         --
-| [A7105-Xeida](ModuleList#markdown-header-xeida-similar-to-v911moduleremovalxeida) ​| 6 | 5 | 2 | 3 | -- | 1 | +| [[modulelist:​a7105#a7105-xeida|A7105-Xeida]] ​         --
-| [XL7105-SY](ModuleList#markdown-header-xl7105-sy-httpwwwebaycomitm171154521980) ​| 2 | 3 | 6 | 7 | -- | 5 | +| [[modulelist:​a7105#xl7105-sy|XL7105-SY]]          --
-| [CYRF6936-DEVO](ModuleList#​markdown-header-devo-httpwwwehirobocomwalkera-wk-devo-s-mod-devo-8-or-12-to-devo-8s-or-12s-upgrade-modulehtml) ​| 1(5V) | 5 | 4 | 8 | 10 | 2 | Connect 9->5 | +| [[modulelist:​cyrf6936#​devo|CYRF6936-DEVO] 1(5V)         10    | Connect 9->5 |
-| [CYRF6936-AWA24S](ModuleList#​markdown-header-awa24s-httpwwwdigikeycomproduct-detailenawa24s748-1003-nd1687150) ​| 2 | 1 | 7 | 5 | 8 | 6 | Connect 10->​11->​2 and 3->12 **(*)** | +| [[modulelist:​cyrf6936#​awa24s|CYRF6936-AWA24S]            | Connect 10->​11->​2 and 3->12 **(*)** |
-| [CYRF6936-BuyChina](ModuleList#​markdown-header-buychina-httpwwwbuychinacomitems2-4g-module-cyrf6936-pa-lna-module-cyrf6936-20dbm-module-uuruunslkhi) ​| 10 | 9 | 2 | 4 | 5 | 1 | Connect 7->11 and 8->12 **(*)** | +| [[modulelist:​cyrf6936#​buychina|CYRF6936-BuyChina] 10            | Connect 7->11 and 8->12 **(*)** |
-| [MultMod v1.2/1.3](ModuleList#​markdown-header-multimod-v12v13-httposhparkcomshared_projectsdf3iwl1j) ​| 2 | 7 | 6 | 4 | 5 | 8 | **See Notes Below** | +| [[modulelist:​multimod#​multimod_v12_v13|MultMod v1.2/1.3]            | **See Notes On Module Page** |
-| [MultiMod v1.4](ModuleList#​markdown-header-multimod-v14) ​| 2 | 7 | 6 | 4 | 5 | 8 | **See Notes Below** | +| [[modulelist:​multimod#​multimod_v14|MultiMod v1.4]            | **See Notes On Module Page** |
- +[[modulelist:3-in-1 module#3-in-1|3-in-1 Module]] ​    |  X  |  X  |  X  |  X  | **See Notes On Module Page** |
-===== CC2500 ===== +[[modulelist:4-in-module#4-in-1|4-in-1 Module]|  ​1  ​|  ​ ​|  ​ ​|  ​8  ​|  10  |  ​ ​| ​**See Notes On Module Page** |
-The CC2500 module is necessary to support the Skyartec and Frsky protocols. It is possible to scavenge this module from a Skyartec transmitter or to purchase it standalone. When searching ebay or aliexpress, searching for ‘CC2500 PA’ will often return reasonable results +
-The small CC2500 is very small - about 17x12 mm. It has no PA and no LNA, It supports some telemetry, as I get voltage but no RSSI. A quick range test showed no problems out to over 100 meters using a FrSky D4R-II, at which point I ran out of room. +
-==== Skyartec : http://​www.skyartec.com/​ProductShow.asp?​ArticleID=1977 ==== +
-The Skyartec module can also be salvaged from a Skyartec Transmitter: ​[[SkyartecModuleRemoval]] +
-{{https://​bitbucket.org/​repo/​Ag6rxe/​images/​2270016736-CC2500-Skyartec.jpg}} +
-*4.0.and earlier: Connect 9->3.3v and 10->​GND. ​ Leave 5 and 7 floating +
-After 4.0.1, connect 5->10 and 7->9. +
-### Aliexpress : http://​www.aliexpress.com/​item/​CC2500-PA-LNA-wireless-module-far-distance-2-4G/​359941652.html ​### +
-![CC2500-Wide.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​143228236-CC2500-Wide.jpg) +
-*4.0.1 and earlier: Connect 9->3.3v and 10->​GND. ​ Leave 5 and 7 floating +
-### XL2500 (Ebay) : http://​www.ebay.com/​itm/​110983783515 ### +
-![491059430-XL2500-D03.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​249670922-491059430-XL2500-D03.jpg) +
-*4.0.and earlier: Connect 9->GND and 10->​3.3v. ​ Leave 3 and 8 floating +
-After 4.0.1, connect ​3->10 and 8->9  +
-### Aliexpress-NoPA : http://​www.aliexpress.com/​item/​1-pcs-CC2500-Wireless-Module-Small-Size-2-4GHz-Wireless-Transceiver-Module-Free-Shipping-Dropshipping/​1566632579.html ### +
-![CC2500-NoPA.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​1241255784-CC2500-NoPA.jpg) +
-### Small-NoPA : http://​www.ebay.com/​itm/​1-8-3-6V-CC2500-IC-Wireless-RF-Transceiver-2-4G-2400MHZ-Module-ISM-SPI-Demo-Code-/​280943872644 ### +
-![SmallCC2500.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​3497153945-SmallCC2500.jpg) +
-## NRF24L01 ## +
-### U.FL Antenna : http://​www.ebay.com/​itm/​400611170500 ### +
-![NRF24L01-PA.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​216789527-NRF24L01-PA.jpg) +
-### XL24L01 : http://​www.ebay.com/​itm/​160763860120 ### +
-![XL24L01-D03.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​2931607708-XL24L01-D03.jpg) +
-## A7105 ## +
-The A7105 module is necessary to support the Flysky protocol (also used by WLToys V911, V9x9, and Xeida 99x8) and the Hubsan X4 protocol. +
-It is possible to scavenge this module from a WLToys Flysky protocol transmitter,​ an Xeida 99x8 transmitter,​ or to purchase it standalone. +
-The XL7105-D03 is an A7105 transceiver with an integrated power-amp providing 17dBm of output power. ​ It can be obtained from Ebay or Aliexpress. ​ Typical search term: ‘A7105-500m’ +
-I have run a range test comparing the XL7105-D03 and V911-Tx modules. ​ In both cases I set the Tx on the ground, the antenna was inside the Tx and was bound to the V911. I then walked until the light on the V911 would flash intermittently. The path was line-of sight, but along the edge of the woods, so not exactly a wide open field. +
-Using the V911 Module: range = 600ft +
-Using the aliexpress module: range = 650ft +
-The XL7105-D03 is rated at 500M, but at least with my setup, I didn’t see any where near that distance. +
-The Xeida module is similar to the WLToys modules, except that it has an antenna on the board, instead of a small attached antenna. A range test similar to the XL7105-D03 and V911-Tx modules (different location, different V911, different Tx) gave a range of about 100 ft. +
-### XL7105-D03 : http://​www.ebay.com/​itm/​181091377178 ### +
-![XL7105-D03.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​2956021120-XL7105-D03.jpg) +
-*4.0.1 and earlier: Connect 8->GND and 9->​3.3V. ​ Leave 6 and 7 floating +
-After 4.0.1, connect 6->9 and 7->8 +
-### V911 : [[V911ModuleRemoval]] ### +
-![A7105-V911.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​454457668-A7105-V911.jpg) +
-### Xeida : Similar to [[V911ModuleRemoval]][xeida] ### +
-![CC-958TG.png](https://​bitbucket.org/​repo/​Ag6rxe/​images/​1750415647-CC-958TG.png) +
-### XL7105-SY : http://​www.ebay.com/​itm/​171154521980 ### +
-![XL7105-SY.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​312503663-XL7105-SY.jpg) +
-## CYRF6936 ## +
-### DEVO : http://​www.ehirobo.com/​walkera-wk-devo-s-mod-devo-8-or-12-to-devo-8s-or-12s-upgrade-module.html ### +
-![CYRF6936-DEVO.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​3966736255-CYRF6936-DEVO.jpg) +
-### AWA24S : http://​www.digikey.com/​product-detail/​en/​AWA24S/​748-1003-ND/​1687150 ### +
-![AWA24S.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​3141475197-AWA24S.jpg) +
-*4.0.1 and earlier: Connect 10->3.3v, 11->3.3v, 12->​GND. ​ Leave 3 and 4 floating +
-After 4.0.1, connect 10->​11->​2 and 3->12 +
-### BuyChina : http://​www.buychina.com/​items/​2-4g-module-cyrf6936-pa-lna-module-cyrf6936-20dbm-module-uuruunslkhi ### +
-![CYRF6936-BuyChina.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​3717190240-CYRF6936-BuyChina.jpg) +
-*4.0.and earlier: Connect 11->GND and 12->​3.3V. ​ Leave 3, 6, 7, and 8 floating +
-After 4.0.1, connect 7->11 and 8->12 +
-## MultiModule ## +
-The MultiModule is a circuit-board + ATTiny AVR chip which can be used to control up to 4 modules on a Deviation Transmitter. +
-The MultiModule is only supported by the nightly-builds at the moment, and will not work with Deviation 4.0.1 or earlier. +
-*If installing a '​DEVO'​ CYRF6936 module into the MultiMod, the 5.0V pin must be connected between the MultiMod and the Transmitter,​ otherwise it can be left floating* +
-*The Reset pin only needs to be connected if you plan to program the AVR via your transmitter. ​ In this case, connect the '​Reset'​ pin to the '​TCK'​ pin of the Devo transmitter* +
-### MultiMod v1.2/v1.3 : http://​oshpark.com/​shared_projects/​Df3iWl1J ### +
-***NOTE: Pin ordering is reversed on this module compared to all other transceiver modules*** +
-![MultiModv1.3.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​3707762924-MultiModv1.3.jpg) +
-### MultiMod v1.4 : ### +
-![MultiModv1.4.jpg](https://​bitbucket.org/​repo/​Ag6rxe/​images/​1149863121-MultiModv1.4.jpg) +
modulelist.1459271573.txt.gz (70 views) · Last modified: 2016/03/29 10:12 by FDR
