modulelist
modulelist [2016/04/15 07:43] FDR [Modules] |
modulelist [2016/12/13 15:33] (current) Arnold |
| Line 1: | Line 1: | ||
| ====== Supported modules ====== | ====== Supported modules ====== | ||
| ===== Pin Ordering ===== | ===== Pin Ordering ===== | ||
| Regardless of how the modules may have their pin-order listed on their data-sheets, this guide uses the following pin ordering (//Except for the Multi-Module-See Below//) | Regardless of how the modules may have their pin-order listed on their data-sheets, this guide uses the following pin ordering (//Except for the Multi-Module-See Below//) | ||
| Line 15: | Line 16: | ||
| (*) - Denotes that alternate connections are required for Deviation 4.0.1 or below. See Module section below for more info | (*) - Denotes that alternate connections are required for Deviation 4.0.1 or below. See Module section below for more info | ||
| - | | Module ^ Power ^ Ground ^ SCK ^ MOSI ^ MISO ^ CSN ^ Notes ^ | + | ^ Module ^ Power ^ Ground ^ SCK ^ MOSI ^ MISO ^ CSN ^ Notes ^ |
| - | | | {{https://bitbucket.org/repo/Ag6rxe/images/4168848131-White.png}} | {{https://bitbucket.org/repo/Ag6rxe/images/2083651818-Black.png}} | {{https://bitbucket.org/repo/Ag6rxe/images/1221698502-Yellow.png}} | {{https://bitbucket.org/repo/Ag6rxe/images/132304774-Purple.png}} | {{https://bitbucket.org/repo/Ag6rxe/images/4056447960-LightGrey.png}} | {{https://bitbucket.org/repo/Ag6rxe/images/883382089-LightBlue.png}} | | + | | | {{https://bitbucket.org/repo/Ag6rxe/images/4168848131-White.png}} | {{https://bitbucket.org/repo/Ag6rxe/images/2083651818-Black.png}} | {{https://bitbucket.org/repo/Ag6rxe/images/1221698502-Yellow.png}} | {{https://bitbucket.org/repo/Ag6rxe/images/132304774-Purple.png}} | {{https://bitbucket.org/repo/Ag6rxe/images/4056447960-LightGrey.png}} | {{https://bitbucket.org/repo/Ag6rxe/images/883382089-LightBlue.png}} | |
| | [[modulelist:cc2500#skyartec|CC2500 Skyartec]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | | | [[modulelist:cc2500#skyartec|CC2500 Skyartec]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | | ||
| | [[modulelist:cc2500#aliexpress|CC2500 Aliexpress]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | | [[modulelist:cc2500#aliexpress|CC2500 Aliexpress]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | ||
| Line 31: | Line 32: | ||
| | [[modulelist:cyrf6936#awa24s|CYRF6936-AWA24S]] | 2 | 1 | 7 | 5 | 8 | 6 | Connect 10->11->2 and 3->12 **(*)** | | | [[modulelist:cyrf6936#awa24s|CYRF6936-AWA24S]] | 2 | 1 | 7 | 5 | 8 | 6 | Connect 10->11->2 and 3->12 **(*)** | | ||
| | [[modulelist:cyrf6936#buychina|CYRF6936-BuyChina]] | 10 | 9 | 2 | 4 | 5 | 1 | Connect 7->11 and 8->12 **(*)** | | | [[modulelist:cyrf6936#buychina|CYRF6936-BuyChina]] | 10 | 9 | 2 | 4 | 5 | 1 | Connect 7->11 and 8->12 **(*)** | | ||
| - | | [[modulelist:multimod#multimod_v12_v13|MultMod v1.2/1.3]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes Below** | | + | | [[modulelist:multimod#multimod_v12_v13|MultMod v1.2/1.3]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes On Module Page** | |
| - | | [[modulelist:multimod#multimod_v14|MultiMod v1.4]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes Below** | | + | | [[modulelist:multimod#multimod_v14|MultiMod v1.4]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes On Module Page** | |
| + | | [[modulelist:3-in-1 module#3-in-1|3-in-1 Module]] | X | X | X | X | X | X | **See Notes On Module Page** | | ||
| + | | [[modulelist:4-in-1 module#4-in-1|4-in-1 Module]] | 1 | 6 | 4 | 8 | 10 | 2 | **See Notes On Module Page** | | ||
modulelist.1460731432.txt.gz (70 views) · Last modified: 2016/04/15 07:43 by FDR
