modulelist
modulelist [2016/04/15 07:43] FDR [Modules] |
modulelist [2016/12/13 15:33] (current) Arnold |
Line 15: | Line 16: | ||
| [[modulelist:cc2500#skyartec|CC2500 Skyartec]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | | | [[modulelist:cc2500#skyartec|CC2500 Skyartec]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | | ||
| [[modulelist:cc2500#aliexpress|CC2500 Aliexpress]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | | [[modulelist:cc2500#aliexpress|CC2500 Aliexpress]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | ||
Line 31: | Line 32: | ||
| [[modulelist:cyrf6936#awa24s|CYRF6936-AWA24S]] | 2 | 1 | 7 | 5 | 8 | 6 | Connect 10->11->2 and 3->12 **(*)** | | | [[modulelist:cyrf6936#awa24s|CYRF6936-AWA24S]] | 2 | 1 | 7 | 5 | 8 | 6 | Connect 10->11->2 and 3->12 **(*)** | | ||
| [[modulelist:cyrf6936#buychina|CYRF6936-BuyChina]] | 10 | 9 | 2 | 4 | 5 | 1 | Connect 7->11 and 8->12 **(*)** | | | [[modulelist:cyrf6936#buychina|CYRF6936-BuyChina]] | 10 | 9 | 2 | 4 | 5 | 1 | Connect 7->11 and 8->12 **(*)** | | ||
- | | [[modulelist:multimod#multimod_v12_v13|MultMod v1.2/1.3]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes Below** | | + | | [[modulelist:multimod#multimod_v12_v13|MultMod v1.2/1.3]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes On Module Page** | |
- | | [[modulelist:multimod#multimod_v14|MultiMod v1.4]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes Below** | | + | | [[modulelist:multimod#multimod_v14|MultiMod v1.4]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes On Module Page** | |
+ | | [[modulelist:3-in-1 module#3-in-1|3-in-1 Module]] | X | X | X | X | X | X | **See Notes On Module Page** | | ||
+ | | [[modulelist:4-in-1 module#4-in-1|4-in-1 Module]] | 1 | 6 | 4 | 8 | 10 | 2 | **See Notes On Module Page** | |
modulelist.1460731432.txt.gz (9725 views) · Last modified: 2016/04/15 07:43 by FDR
