playground:playground
playground:playground [2017/10/15 17:53] MikeNH [Sandbox page for testing formatting, etc] |
playground:playground [2017/10/15 18:41] MikeNH [Sandbox page for testing formatting, etc] |
Line 2: | Line 2: | ||
Contributing documentation to the Deviation project as a user can be valuable to all users. The process of creating a Wiki document can be daunting if it's a once-in-a-while activity. Our goal in this How-To doc is to provide the simple steps to create your document. \\ | Contributing documentation to the Deviation project as a user can be valuable to all users. The process of creating a Wiki document can be daunting if it's a once-in-a-while activity. Our goal in this How-To doc is to provide the simple steps to create your document. \\ | ||
- | The full reference for creating and formatting Wiki documents can be found [[wiki:syntax|here]]. \\ | + | Here's links to complete references for **[[https://www.dokuwiki.org/page| creating]]** and **[[wiki:syntax|formatting]]** Wiki documents.\\ |
- | These steps are only to create a new internal document. Here we go... \\ | + | You need to have registered and to be logged in to create a document. \\ |
- | 2 - | + | 2 - Go to the [[https://www.deviationtx.com/wiki/guides#programming_guides|Programming guides]] page. \\ |
+ | 3 - Choose Edit in either the Tutorials or How-Tos section. \\ | ||
+ | 4 - Using the following syntax (without quotes), add the text for the new link: | ||
playground/playground.txt (50443 views) · Last modified: 2018/05/02 23:39 (external edit)
