playground:playground
playground:playground [2017/10/15 18:36] MikeNH [Sandbox page for testing formatting, etc] |
playground:playground [2018/05/02 23:39] |
- | ====== 3-in-1 Module ====== | ||
- | Adding this module to your Devo supplies the CC2500, A7105, and NRF24L01 RF modules in one package. Each module uses the one common antenna connection that is provided on the package. | ||
- | Here's links to references for **[[https://www.dokuwiki.org/page| creating]]** and **[[wiki:syntax|formatting]]** Wiki documents.\\ | ||
- | 3 - Click Edit in either the Tutorials or How-Tos section. \\ | ||
- | 4 - Using the following syntax, add the text for the new link: | ||
- | "* [[The title for my new document]]" | ||
- | 5 - Save the document and you'll see the link in red text. |
playground/playground.txt (48891 views) · Last modified: 2018/05/02 23:39 (external edit)
