release_notes:5.0.0
release_notes:5.0.0 [2016/04/27 07:03] PhracturedBlue |
- | **IMPORTANT: You must install the filesystem along with the new firmware. Make sure to save your models first!** | + | **The configuration of hardware mods has changed since the previous 4.0.1 version. Instead of the tx.ini, they are in a new hardware.ini file, just like it was in the last nightly builds.** |
* Follow the instructions in the [[ http://www.deviationtx.com/user-manual | User Manual ]] that applies to your transmitter | * Follow the instructions in the [[ http://www.deviationtx.com/user-manual | User Manual ]] that applies to your transmitter | ||
+ | * Fix date displays | ||
+ | * Protocol fixes | ||
+ | * YD717 - Don't hange the transmitter waiting fro a response from the model | ||
- | + | * SymaX | |
- | * DSM2/DSMX fixes for lost binding during operation | + | * YD717 now supports Sky Walker 1306 |
+ | * H377 protocol | ||
+ | * HM380 protocol | ||
+ | * KN (V977) protocol | ||
+ | * ESky150 protocol | ||
+ | * Bluefly HP100 | ||
+ | * CX10 protocol | ||
+ | * Joysway protocol | ||
+ | * Hontai protocol | ||
+ | * FY326 protocol | ||
+ | * MJXq protocol | ||
+ | * H8_3d protocol | ||
release_notes/5.0.0.txt (28267 views) · Last modified: 2017/05/17 08:03 by Texacate
