release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 10:28] PhracturedBlue |
- | **IMPORTANT: You must install the filesystem along with the new firmware. Make sure to save your models first!** | + | **The configuration of hardware mods has changed since the previous 4.0.1 version. Instead of the tx.ini, they are in a new hardware.ini file, just like it was in the last nightly builds.** |
Line 29: | Line 29: | ||
* Improve scrolling on many of the GUI screens | * Improve scrolling on many of the GUI screens | ||
* Support viewing virtual channels on Channel-test page | * Support viewing virtual channels on Channel-test page | ||
- | * Telemetry alars are moe prominent | + | * Telemetry alarms are more prominent |
* Properly display PPMIN on main page | * Properly display PPMIN on main page | ||
* Add debug log display option | * Add debug log display option | ||
Line 42: | Line 45: | ||
* DSM2/X - support extended telemetry info | * DSM2/X - support extended telemetry info | ||
* DSM2/X - fix GPS heading units | * DSM2/X - fix GPS heading units | ||
* WK* - Show dialog until biding is complete | * WK* - Show dialog until biding is complete | ||
* USBHID - Support up to 12 channels | * USBHID - Support up to 12 channels | ||
Line 49: | Line 53: | ||
* HiSky - Support 3/6 axis option | * HiSky - Support 3/6 axis option | ||
* Devo - Fix loss of signal issue with telemetry enabled | * Devo - Fix loss of signal issue with telemetry enabled | ||
==== New protocols ==== | ==== New protocols ==== | ||
Line 64: | Line 69: | ||
* CX10 protocol | * CX10 protocol | ||
* CG023 protocol - supports EAchine CG023 / 3D X4 / Attop YD-829(C) | * CG023 protocol - supports EAchine CG023 / 3D X4 / Attop YD-829(C) | ||
+ | * Joysway protocol | ||
+ | * Hontai protocol | ||
+ | * FY326 protocol | ||
+ | * MJXq protocol | ||
+ | * H8_3d protocol | ||
release_notes/5.0.0.txt (32714 views) · Last modified: 2017/05/17 08:03 by Texacate
