release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 12:56] Arnold [Minor Features / Bug Fixes] |
- | ** NOTE: Deviation 5.0.0 has not been released yet. These release notes are a work-in progress** | + | **IMPORTANT:**\\ |
Line 34: | Line 34: | ||
* Support newer Devo12S (with Rev2 Epson LCD driver) | * Support newer Devo12S (with Rev2 Epson LCD driver) | ||
* Fix channel mapping when loading templates | * Fix channel mapping when loading templates | ||
- | * Remove hardcoded fonts to improve themability | + | * Remove hardcoded fonts to improve theme-ability |
Line 76: | Line 76: | ||
release_notes/5.0.0.txt (27893 views) · Last modified: 2017/05/17 08:03 by Texacate
