release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 13:54] FDR |
release_notes:5.0.0 [2017/05/17 08:03] Texacate added the date 5.0.0 was released |
- | **IMPORTANT: You must install the filesystem along with the new firmware. Make sure to save your models first!** | + | Version 5.0.0 was released on 2016-04-30 |
+ | **IMPORTANT:**\\ | ||
Line 38: | Line 42: | ||
Line 74: | Line 78: | ||
release_notes/5.0.0.txt (25919 views) · Last modified: 2017/05/17 08:03 by Texacate
