release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 13:54] FDR |
- | **IMPORTANT: You must install the filesystem along with the new firmware. Make sure to save your models first!** | + | Version 5.0.0 was released on 2016-04-30 |
+ | **IMPORTANT:**\\ | ||
Line 38: | Line 42: | ||
Line 74: | Line 78: | ||
release_notes/5.0.0.1462049667.txt.gz (32824 views) · Last modified: 2016/04/30 13:54 by FDR
