release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 22:37] victzh [New protocols] Missed S-FHSS |
release_notes:5.0.0 [2017/05/17 08:03] Texacate added the date 5.0.0 was released |
- | **IMPORTANT: You must install the filesystem along with the new firmware. Make sure to save your models first!** | + | Version 5.0.0 was released on 2016-04-30 |
+ | **IMPORTANT:**\\ | ||
Line 38: | Line 42: | ||
* DSM2/X - telemetry display fixes. Support temperature display | * DSM2/X - telemetry display fixes. Support temperature display |
release_notes/5.0.0.txt (23414 views) · Last modified: 2017/05/17 08:03 by Texacate
