release_notes:5.0.0
release_notes:5.0.0 [2017/05/17 08:03] Texacate added the date 5.0.0 was released |
+ | Version 5.0.0 was released on 2016-04-30 | ||
**IMPORTANT:**\\ | **IMPORTANT:**\\ | ||
**You must install the filesystem along with the new firmware. Make sure to save your models first!**\\ | **You must install the filesystem along with the new firmware. Make sure to save your models first!**\\ | ||
Line 5: | Line 7: | ||
Line 40: | Line 42: | ||
* DSM2/X - telemetry display fixes. Support temperature display | * DSM2/X - telemetry display fixes. Support temperature display |
release_notes/5.0.0.txt (23396 views) ยท Last modified: 2017/05/17 08:03 by Texacate
