release_notes:5.0.0
release_notes:5.0.0 [2016/04/27 06:16] PhracturedBlue |
| Line 1: | Line 1: | ||
| ===== Version 5.0.0 ===== | ===== Version 5.0.0 ===== | ||
| - | ** NOTE: Deviation 5.0.0 has not been released yet. There release notes are a work-in progress** | + | Version 5.0.0 was released on 2016-04-30 |
| - | **IMPORTANT: You must install the filesystem along with the new firmware. Make sure to save your models first!** | + | **IMPORTANT:**\\ |
| + | **You must install the filesystem along with the new firmware. Make sure to save your models first!**\\ | ||
| + | **The configuration of hardware mods has changed since the previous 4.0.1 version. Instead of the tx.ini, they are in a new hardware.ini file, just like they were in the last nightly builds.** | ||
| ==== Installation ==== | ==== Installation ==== | ||
| - | * Follow the instructions in the [[ http://www.deviationtx.com/user-manual | User Manual ]] that applies to your transmitter | + | * Follow the instructions in the [[ https://www.deviationtx.com/user-manual | User Manual ]] that applies to your transmitter |
| + | ==== Critical bug fixes ==== | ||
| + | * DSM2/DSMX fixes for lost binding during operation | ||
| ==== Major Features ==== | ==== Major Features ==== | ||
| + | * Allow reordering mixers on Devo7e/10 | ||
| + | * Reworked telemetry to have different displays for different protocols | ||
| + | * Add Range Test capability | ||
| + | * Support permanent timers | ||
| + | ==== Minor Features / Bug Fixes ==== | ||
| + | * Support hardware modification to add extra switches to the devo7e | ||
| + | * Support hardware modification to add vibration for Devo6/8 | ||
| + | * Add support for multi-module | ||
| + | * Automatically reorder channels when changing protocols | ||
| + | * Support smaller fonts in Devo7e | ||
| + | * Improve volume control | ||
| + | * Fix telemetry alarms | ||
| + | * Fix power output contol for CC2500 protocols | ||
| + | * Fix date displays | ||
| + | * Support 4 alarm sounds for timers | ||
| + | * Improve scrolling on many of the GUI screens | ||
| + | * Support viewing virtual channels on Channel-test page | ||
| + | * Telemetry alarms are more prominent | ||
| + | * Properly display PPMIN on main page | ||
| + | * Add debug log display option | ||
| + | * Support newer Devo12S (with Rev2 Epson LCD driver) | ||
| + | * Fix channel mapping when loading templates | ||
| + | * Remove hardcoded fonts to improve theme-ability | ||
| + | * Protocol fixes | ||
| + | * YD717 - Fix channels for rudder, aileron, elevator | ||
| + | * YD717 - Use random channels to allow multiple vehicles to fly in the same area | ||
| + | * YD717 - Enable high-rate mode | ||
| + | * YD717 - Support receiver throttle saftey | ||
| + | * YD717 - Don't hang the transmitter waiting for a response from the model | ||
| + | * Properly handle Tx mode in Hubsan protocol | ||
| + | * DSM2/X - telemetry display fixes. Support temperature display | ||
| + | * DSM2/X - support extended telemetry info | ||
| + | * DSM2/X - fix GPS heading units | ||
| + | * DSM2/X - RSSI in dBM | ||
| + | * WK* - Show dialog until biding is complete | ||
| + | * USBHID - Support up to 12 channels | ||
| + | * V202 - Support bind on power-up | ||
| + | * PPMOUT - Allow more than 10 channels | ||
| + | * V202 - Add 250kbps mode, headless, and calibration | ||
| + | * HiSky - Support 3/6 axis option | ||
| + | * Devo - Fix loss of signal issue with telemetry enabled | ||
| + | * Flysky - Update packet period to increase compatibilty with more receivers | ||
| - | ==== Minor Features ==== | + | ==== New protocols ==== |
| - | + | * SymaX | |
| - | ==== Critical bug fixes ==== | + | * Frsky 2-way and V8 protocols |
| + | * YD717 now supports Sky Walker 1306 | ||
| + | * YD717 supports XinXun | ||
| + | * Crazyflie 'CFlie' protocol | ||
| + | * H377 protocol | ||
| + | * HM380 protocol | ||
| + | * KN (V977) protocol | ||
| + | * ESky150 protocol | ||
| + | * Bluefly HP100 | ||
| + | * Flysky supports WLToys V6x6, v919, v913 v915 | ||
| + | * CX10 protocol | ||
| + | * CG023 protocol - supports EAchine CG023 / 3D X4 / Attop YD-829(C) | ||
| + | * Joysway protocol | ||
| + | * Hontai protocol | ||
| + | * MT99 protocol - Supports Eachine H7 | ||
| + | * FY326 protocol | ||
| + | * Bayang protocol - Supports H8 model and others | ||
| + | * MJXq protocol | ||
| + | * H8_3d protocol | ||
| + | * Futaba S-FHSS protocol | ||
release_notes/5.0.0.1461762965.txt.gz (3373 views) · Last modified: 2016/04/27 06:16 by PhracturedBlue
