release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 12:56] Arnold [Minor Features / Bug Fixes] |
- | ** NOTE: Deviation 5.0.0 has not been released yet. These release notes are a work-in progress** | + | Version 5.0.0 was released on 2016-04-30 |
Line 34: | Line 36: | ||
* Support newer Devo12S (with Rev2 Epson LCD driver) | * Support newer Devo12S (with Rev2 Epson LCD driver) | ||
* Fix channel mapping when loading templates | * Fix channel mapping when loading templates | ||
- | * Remove hardcoded fonts to improve themability | + | * Remove hardcoded fonts to improve theme-ability |
Line 40: | Line 42: | ||
Line 76: | Line 78: | ||
release_notes/5.0.0.1462046194.txt.gz (23553 views) · Last modified: 2016/04/30 12:56 by Arnold
