release_notes:5.0.0
+ | Version 5.0.0 was released on 2016-04-30 | ||
**IMPORTANT:**\\ | **IMPORTANT:**\\ | ||
**You must install the filesystem along with the new firmware. Make sure to save your models first!**\\ | **You must install the filesystem along with the new firmware. Make sure to save your models first!**\\ | ||
Line 5: | Line 7: | ||
Line 40: | Line 42: | ||
* DSM2/X - telemetry display fixes. Support temperature display | * DSM2/X - telemetry display fixes. Support temperature display |
release_notes/5.0.0.1462090733.txt.gz (23487 views) ยท Last modified: 2016/05/01 01:18 by FDR
