release_notes:5.0.0
release_notes:5.0.0 [2016/04/27 07:03] PhracturedBlue |
- | ** NOTE: Deviation 5.0.0 has not been released yet. There release notes are a work-in progress** | + | Version 5.0.0 was released on 2016-04-30 |
- | ==== Major Features ==== | + | |
- | ==== Minor Features ==== | + | |
* DSM2/DSMX fixes for lost binding during operation | * DSM2/DSMX fixes for lost binding during operation | ||
+ | ==== Major Features ==== | ||
+ | * Fix date displays | ||
+ | * Protocol fixes | ||
+ | ==== New protocols ==== | ||
+ | * SymaX | ||
+ | * Frsky 2-way and V8 protocols | ||
+ | * YD717 now supports Sky Walker 1306 | ||
+ | * H377 protocol | ||
+ | * HM380 protocol | ||
+ | * KN (V977) protocol | ||
+ | * ESky150 protocol | ||
+ | * Bluefly HP100 | ||
+ | * CX10 protocol | ||
+ | * Joysway protocol | ||
+ | * Hontai protocol | ||
+ | * FY326 protocol | ||
+ | * MJXq protocol | ||
+ | * H8_3d protocol | ||
release_notes/5.0.0.1461765818.txt.gz (128206 views) · Last modified: 2016/04/27 07:03 by PhracturedBlue
