release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 22:37]
victzh [New protocols] Missed S-FHSS
release_notes:5.0.0 [2017/05/17 08:03] (current)
Texacate added the date 5.0.0 was released
Line 1: Line 1:
 ===== Version 5.0.0 ===== ===== Version 5.0.0 =====
-**IMPORTANT:​ You must install the filesystem along with the new firmware. ​ Make sure to save your models first!**+Version 5.0.0 was released on 2016-04-30
 +**IMPORTANT:​**\\
 +**You must install the filesystem along with the new firmware. ​ Make sure to save your models first!**\\
 +**The configuration of hardware mods has changed since the previous 4.0.1 version. Instead of the tx.ini, they are in a new hardware.ini file, just like they were in the last nightly builds.**
 ==== Installation ==== ==== Installation ====
-  * Follow the instructions in the [[ http://​www.deviationtx.com/​user-manual | User Manual ]] that applies to your transmitter+  * Follow the instructions in the [[ https://​www.deviationtx.com/​user-manual | User Manual ]] that applies to your transmitter
 ==== Critical bug fixes ==== ==== Critical bug fixes ====
Line 38: Line 42:
       * YD717 - Enable high-rate mode       * YD717 - Enable high-rate mode
       * YD717 - Support receiver throttle saftey       * YD717 - Support receiver throttle saftey
-      * YD717 - Don'​t ​hange the transmitter waiting ​fro a response from the model+      * YD717 - Don'​t ​hang the transmitter waiting ​for a response from the model
       * Properly handle Tx mode in Hubsan protocol       * Properly handle Tx mode in Hubsan protocol
       * DSM2/X - telemetry display fixes. ​ Support temperature display       * DSM2/X - telemetry display fixes. ​ Support temperature display
release_notes/5.0.0.1462081028.txt.gz (128203 views) · Last modified: 2016/04/30 22:37 by victzh
