rf_module_installation:devo7e
rf_module_installation:devo7e [2016/04/15 09:06] FDR [Module Installation] |
rf_module_installation:devo7e [2016/04/15 09:10] FDR [Module Installation] |
Line 15: | Line 15: | ||
- | Follow the table and images on the [[modulelist|ModuleList]] page to determine the necessary connections for your modules. See the Image below for the relevant connection points on the Devo7e: | + | Follow the table and images on the [[:modulelist|Module List]] page to determine the necessary connections for your modules. See the Image below for the relevant connection points on the Devo7e: |
Pins MISO, MOSI, and SCK connect to the CYRF6936 Module. | Pins MISO, MOSI, and SCK connect to the CYRF6936 Module. |
rf_module_installation/devo7e.txt (46140 views) ยท Last modified: 2016/04/15 12:01 by FDR
