rf_module_installation:devo8
rf_module_installation:devo8 [2016/04/14 19:49] PhracturedBlue created |
rf_module_installation:devo8 [2016/04/15 12:01] FDR [Installing a module into a Devo8 Transmitter] |
===== Installing a module into a Devo8 Transmitter ===== | ===== Installing a module into a Devo8 Transmitter ===== | ||
==== Prepare Devo Transmitter ==== | ==== Prepare Devo Transmitter ==== | ||
First Remove the screws from the back of the Devo8 Transmitter | First Remove the screws from the back of the Devo8 Transmitter | ||
Line 14: | Line 14: | ||
- | Follow the table and images on the [[ModuleList]] page to determine the necessary connections for your modules. See the Image below for the relevant connection points on the Devo8: | + | Follow the table and images on the [[:modulelist|Module List]] page to determine the necessary connections for your modules. See the Image below for the relevant connection points on the Devo8: |
Pins MISO, MOSI, and SCK connect to the CYRF6936 Module: | Pins MISO, MOSI, and SCK connect to the CYRF6936 Module: |
rf_module_installation/devo8.txt (53003 views) ยท Last modified: 2016/04/15 12:01 by FDR
