rf_module_installation:devo8
rf_module_installation:devo8 [2016/04/15 09:09] FDR [Module Installation] |
rf_module_installation:devo8 [2016/04/15 09:11] FDR [Module Installation] |
Line 14: | Line 14: | ||
- | Follow the table and images on the [[/modulelist|Module List]] page to determine the necessary connections for your modules. See the Image below for the relevant connection points on the Devo8: | + | Follow the table and images on the [[:modulelist|Module List]] page to determine the necessary connections for your modules. See the Image below for the relevant connection points on the Devo8: |
Pins MISO, MOSI, and SCK connect to the CYRF6936 Module: | Pins MISO, MOSI, and SCK connect to the CYRF6936 Module: |
rf_module_installation/devo8.txt (45431 views) ยท Last modified: 2016/04/15 12:01 by FDR
