rf_module_installation
rf_module_installation [2016/03/27 14:10] mwm created |
rf_module_installation [2016/04/14 19:49] PhracturedBlue |
Each can control a different set of modules/receivers. A (mostly complete) list of models and the corresponding modules can be found in the [[https://docs.google.com/spreadsheet/ccc?key=0Any72n5Y9u-kdGFDeXhBY0I0ek1raTdEN21VTlBzTkE&usp=sharing|Supported Models]] list. More information on each module as well as hints on where to obtain them can be found on the [[ModuleList]] page. Information how to build a "universal module" can be found here [[Building the Multi-Module]]. | Each can control a different set of modules/receivers. A (mostly complete) list of models and the corresponding modules can be found in the [[https://docs.google.com/spreadsheet/ccc?key=0Any72n5Y9u-kdGFDeXhBY0I0ek1raTdEN21VTlBzTkE&usp=sharing|Supported Models]] list. More information on each module as well as hints on where to obtain them can be found on the [[ModuleList]] page. Information how to build a "universal module" can be found here [[Building the Multi-Module]]. | ||
- | //NOTE: Read through this entire manual before starting work. Make sure you understand what is needed and how to do it. Also, ths procedure will void the warranty of your Devo transmitter in the process of implementing this modification.// | + | //NOTE: Read through this entire manual before starting work. Make sure you understand what is needed and how to do it. Also, this procedure will void the warranty of your Devo transmitter in the process of implementing this modification.// |
==== Necessary Tools ==== | ==== Necessary Tools ==== | ||
- | * Transceiver module (A7105, CC2500, NRF24L01, CYRF6936, or 'Universal Module' | + | * Transceiver module (A7105, CC2500, NRF24L01, CYRF6936, or 'Universal Module') |
* Small Phillips-head screwdriver | * Small Phillips-head screwdriver | ||
* Solder-sucker or solder wick (strongly recommended) | * Solder-sucker or solder wick (strongly recommended) | ||
Line 23: | Line 23: | ||
- | * Devo8 (and Devo6, Devo10, Devo12): [[Devo8ModuleInstall]] | + | * Devo8 (and Devo6, Devo10, Devo12): [[Devo8]] |
- | * Devo7e: [[Devo7eModuleInstall]] | + | * Devo7e: [[Devo7e]] |
After you have installed the module, you will need to enable them by editing a file on your transmitter. This is described in [[Enabling modules]]. | After you have installed the module, you will need to enable them by editing a file on your transmitter. This is described in [[Enabling modules]]. |
rf_module_installation.txt (26925 views) · Last modified: 2017/01/23 00:30 by FDR
