rf_module_installation
rf_module_installation [2016/03/29 10:07] FDR typo |
rf_module_installation [2016/04/14 19:49] PhracturedBlue |
Line 10: | Line 10: | ||
==== Necessary Tools ==== | ==== Necessary Tools ==== | ||
- | * Transceiver module (A7105, CC2500, NRF24L01, CYRF6936, or 'Universal Module' | + | * Transceiver module (A7105, CC2500, NRF24L01, CYRF6936, or 'Universal Module') |
* Small Phillips-head screwdriver | * Small Phillips-head screwdriver | ||
* Solder-sucker or solder wick (strongly recommended) | * Solder-sucker or solder wick (strongly recommended) | ||
Line 23: | Line 23: | ||
- | * Devo8 (and Devo6, Devo10, Devo12): [[Devo8ModuleInstall]] | + | * Devo8 (and Devo6, Devo10, Devo12): [[Devo8]] |
- | * Devo7e: [[Devo7eModuleInstall]] | + | * Devo7e: [[Devo7e]] |
After you have installed the module, you will need to enable them by editing a file on your transmitter. This is described in [[Enabling modules]]. | After you have installed the module, you will need to enable them by editing a file on your transmitter. This is described in [[Enabling modules]]. |
rf_module_installation.txt (26926 views) · Last modified: 2017/01/23 00:30 by FDR
