rf_module_installation
rf_module_installation [2016/04/15 12:05] FDR [Adding External Modules to Your Deviation Transmitter] |
Each can control a different set of modules/receivers. A (mostly complete) list of models and the corresponding modules can be found in the [[https://docs.google.com/spreadsheet/ccc?key=0Any72n5Y9u-kdGFDeXhBY0I0ek1raTdEN21VTlBzTkE&usp=sharing|Supported Models]] list. More information on each module as well as hints on where to obtain them can be found on the [[ModuleList]] page. Information how to build a "universal module" can be found here [[Building the Multi-Module]]. | Each can control a different set of modules/receivers. A (mostly complete) list of models and the corresponding modules can be found in the [[https://docs.google.com/spreadsheet/ccc?key=0Any72n5Y9u-kdGFDeXhBY0I0ek1raTdEN21VTlBzTkE&usp=sharing|Supported Models]] list. More information on each module as well as hints on where to obtain them can be found on the [[ModuleList]] page. Information how to build a "universal module" can be found here [[Building the Multi-Module]]. | ||
Line 23: | Line 24: | ||
- | * Devo8 (and Devo6, Devo10, Devo12): [[f_module_installation:Devo8|Devo8]] | + | * [[rf_module_installation:Devo8|Devo8 (and Devo6, Devo10, Devo12)]] |
- | * Devo7e: [[f_module_installation:Devo7e|Devo7e]] | + | * [[rf_module_installation:Devo7e|Devo7e]] |
rf_module_installation.txt (8567 views) · Last modified: 2017/01/23 00:30 by FDR
