rf_module_installation
rf_module_installation [2016/03/29 10:07] FDR typo |
rf_module_installation [2017/01/23 00:30] FDR link |
//NOTE: Read through this entire manual before starting work. Make sure you understand what is needed and how to do it. Also, this procedure will void the warranty of your Devo transmitter in the process of implementing this modification.// | //NOTE: Read through this entire manual before starting work. Make sure you understand what is needed and how to do it. Also, this procedure will void the warranty of your Devo transmitter in the process of implementing this modification.// | ||
==== Necessary Tools ==== | ==== Necessary Tools ==== | ||
- | * Transceiver module (A7105, CC2500, NRF24L01, CYRF6936, or 'Universal Module' | + | * Transceiver module (A7105, CC2500, NRF24L01, CYRF6936, or 'Universal Module') |
* Small Phillips-head screwdriver | * Small Phillips-head screwdriver | ||
* Solder-sucker or solder wick (strongly recommended) | * Solder-sucker or solder wick (strongly recommended) | ||
Line 23: | Line 24: | ||
- | * Devo8 (and Devo6, Devo10, Devo12): [[Devo8ModuleInstall]] | + | * [[rf_module_installation:Devo8|Devo8 (and Devo6, Devo10, Devo12)]] |
- | * Devo7e: [[Devo7eModuleInstall]] | + | * [[rf_module_installation:Devo7e|Devo7e]] |
rf_module_installation.txt (1756 views) · Last modified: 2017/01/23 00:30 by FDR
