start [2016/04/15 18:36] PhracturedBlue |
start [2017/04/23 23:27] FDR [Getting Started] |
+ | * Read the manual | ||
- | Here is a list of transmitter MCU pinouts: [[hardware]] | + | Whether your interest is in building the code yourself, or understanding the hardware the Deviation runs on, you can find more information on our [[development]] page |
start.txt (99125 views) · Last modified: 2020/08/18 02:45 by kestel
