start [2016/04/15 19:04] PhracturedBlue |
start [2017/01/23 00:31] FDR https |
+ | * Read the manual | ||
+ | *[[https://www.deviationtx.com/user-manual/user-manual-7e-10|DEVO 7E/10]] | ||
- | Here is a list of transmitter MCU pinouts: [[hardware]] | + | Whether your interest is in building the code yourself, or understanding the hardware the Deviation runs on, you can find more information on our [[development]] page |
- | Building Deviation on Windows: [[development/building_on_windows]] | + |
start.txt (99286 views) · Last modified: 2020/08/18 02:45 by kestel
