start [2016/04/15 19:04] PhracturedBlue |
start [2019/02/08 00:21] csujun Add SPI Flash chip |
+ | * Read the manual | ||
- | Here is a list of model files that have been submitted by the DeviationTx forum users: [[model_config]] | + | [[voiceoutput|Adding module for voice output]] |
- | Here is a list of transmitter MCU pinouts: [[hardware]] | + | Whether your interest is in building the code yourself, or understanding the hardware the Deviation runs on, you can find more information on our [[development]] page |
- | Building Deviation on Windows: [[development/building_on_windows]] | + |
start.txt (76821 views) · Last modified: 2020/08/18 02:45 by kestel
