start [2016/04/17 01:27] FDR [Hardware modifications] |
start [2016/05/09 18:57] RoGuE_StreaK [Hardware & Modifications] |
+ | * Read the manual | ||
+ | *[[http://www.deviationtx.com/user-manual/user-manual-6-8-12|DEVO 6/8/12]] | ||
+ | *[[http://www.deviationtx.com/user-manual/user-manual-7e-10|DEVO 7E/10]] | ||
- | [[transmiterswitches|Transmiter Switches]] | + | ---- |
+ | *[[http://www.deviationtx.com/forum/index|Ask in the forums]] but do a search first | ||
- | ===== List of Example Model Configurations ===== | + | ---- |
- | Here is a [[model_config|list of model files]] that have been submitted by the DeviationTx forum users | + | |
start.txt (99498 views) · Last modified: 2020/08/18 02:45 by kestel
