start [2016/04/17 01:27] FDR [Hardware modifications] |
start [2017/01/23 00:31] FDR https |
+ | * Read the manual | ||
+ | *[[https://www.deviationtx.com/user-manual/user-manual-7e-10|DEVO 7E/10]] | ||
- | [[transmiterswitches|Transmiter Switches]] | + | ---- |
- | Here is a [[model_config|list of model files]] that have been submitted by the DeviationTx forum users | + | [[transmiterswitches|Transmitter Switches]] |
start.txt (98561 views) · Last modified: 2020/08/18 02:45 by kestel
