start [2016/04/17 01:27] FDR [Hardware modifications] |
start [2018/11/20 00:46] csujun fix typo |
+ | * Read the manual | ||
- | [[transmiterswitches|Transmiter Switches]] | + | ---- |
- | Here is a [[model_config|list of model files]] that have been submitted by the DeviationTx forum users | + | [[voiceoutput|Adding module for voice output]] |
start.txt (66774 views) · Last modified: 2020/08/18 02:45 by kestel
