start [2016/04/17 01:25] FDR [Development] |
+ | * Read the manual | ||
+ | === Voice output === | ||
- | ===== List of Example Model Configurations ===== | + | === Change SPI Flash Chip === |
- | Here is a list of model files that have been submitted by the DeviationTx forum users: [[model_config]] | + | [[spiflash| Supported SPI Flash Chips]] |
start.1460881522.txt.gz (29704 views) · Last modified: 2016/04/17 01:25 by FDR
