start [2016/04/17 01:27] FDR [Hardware modifications] |
+ | * Read the manual | ||
- | [[transmiterswitches|Transmiter Switches]] | + | ---- |
+ | === Voice output === | ||
- | ===== List of Example Model Configurations ===== | + | === Change SPI Flash Chip === |
- | Here is a [[model_config|list of model files]] that have been submitted by the DeviationTx forum users | + | [[spiflash| Supported SPI Flash Chips]] |
start.1460881631.txt.gz (34742 views) · Last modified: 2016/04/17 01:27 by FDR
