transmiterswitches
transmiterswitches [2016/04/26 15:24] RoGuE_StreaK [Switches available] |
transmiterswitches [2017/05/21 12:03] mwm |
- | * **Modded**((There are published hardware mods for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. Additionally two pairs of Trims can be added using existing through holes. These are supported by the latest nightly builds. Adding both switches and trims brings the number of inputs on the 6/6S to the same level as the 8/8S)): \\ SW A0, SW A1, SW A2, SW B0, SW B1 | + | * **Modded**((There are [[http://www.rcgroups.com/forums/showthread.php?t=2536181|published hardware mods]] for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. Additionally two pairs of Trims can be added using existing through holes. These are supported in 5.0 and later. Adding both switches and trims brings the number of inputs on the 6/6S to the same level as the 8/8S/10/F12E)): \\ (SW A0, SW A1, SW A2) or (SW A0, SW A1, SW B0, SW B1) |
+ | * **Devo F4**: | ||
transmiterswitches.txt (127657 views) · Last modified: 2017/05/21 12:03 by mwm
