transmiterswitches
transmiterswitches [2016/04/26 15:29] RoGuE_StreaK [Switches available] |
transmiterswitches [2016/07/03 23:39] FDR |
Line 5: | Line 5: | ||
- | * **Modded**((There are published hardware mods for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. Additionally two pairs of Trims can be added using existing through holes. These are supported by the latest nightly builds. Adding both switches and trims brings the number of inputs on the 6/6S to the same level as the 8/8S/10/12E)): \\ (SW A0, SW A1, SW A2) or (SWA0, SWA1, SW B0, SW B1) | + | * **Modded**((There are [[http://www.rcgroups.com/forums/showthread.php?t=2536181|published hardware mods]] for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. Additionally two pairs of Trims can be added using existing through holes. These are supported in 5.0 and later. Adding both switches and trims brings the number of inputs on the 6/6S to the same level as the 8/8S/10/F12E)): \\ (SW A0, SW A1, SW A2) or (SW A0, SW A1, SW B0, SW B1) |
- | * **Modded**((There are published hardware modes for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported by the latest nightly builds)): \\ SW A0, SW A1, SW A2, SW B0, SW B1, SW B2 | + | * **Modded**((There are published hardware modes for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported in 5.0 and later)): \\ SW A0, SW A1, SW A2, SW B0, SW B1, SW B2 |
* **Devo8** and **Devo10** and **Devo F12E**: \\ RUD DR0, RUD DR1, ELE DR0, ELE DR1, AIL DR0, AIL DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2 | * **Devo8** and **Devo10** and **Devo F12E**: \\ RUD DR0, RUD DR1, ELE DR0, ELE DR1, AIL DR0, AIL DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2 | ||
Line 16: | Line 16: | ||
* **Devo F7**: \\ AIL_DR0, AIL_DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2 | * **Devo F7**: \\ AIL_DR0, AIL_DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2 | ||
The lack of switches on the Devo7e and Devo6 can be dealt with by using the *Trim as Virtual Switch*. See the manual for details on how to set those up. Using the throttle trim switches as a pair works well, and the buttons beside the LCD can be used as push-button switches. | The lack of switches on the Devo7e and Devo6 can be dealt with by using the *Trim as Virtual Switch*. See the manual for details on how to set those up. Using the throttle trim switches as a pair works well, and the buttons beside the LCD can be used as push-button switches. |
transmiterswitches.txt (140253 views) ยท Last modified: 2017/05/21 12:03 by mwm
