transmiterswitches
transmiterswitches [2016/04/15 08:38] FDR [Switches available] |
- | The one serious issue when porting model files is that the new model may not have the same set of switces as the old one. In order to help people wanting to port a model file to a model they don't have, I've provided a list of switches here, listing the tx's in numerical order. | + | The one serious issue when porting model files is that the new transmitter may not have the same set of switches as the old one. In order to help people wanting to port a model file fram a transmitter they don't have, I've provided a list of switches here, listing the tx's in numerical order. |
- | * **Modded**((There are published hardware mods for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. These are supported by the latest nightly builds)): \\ SW A0, SW A1, SW A2, SW B0, SW B1 | + | * **Modded**((There are [[http://www.rcgroups.com/forums/showthread.php?t=2536181|published hardware mods]] for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. Additionally two pairs of Trims can be added using existing through holes. These are supported in 5.0 and later. Adding both switches and trims brings the number of inputs on the 6/6S to the same level as the 8/8S/10/F12E)): \\ (SW A0, SW A1, SW A2) or (SW A0, SW A1, SW B0, SW B1) |
+ | * **Devo F4**: | ||
transmiterswitches.1460734709.txt.gz (130605 views) · Last modified: 2016/04/15 08:38 by FDR
