transmiterswitches
transmiterswitches [2016/04/14 19:30] PhracturedBlue created |
- | The one serious issue when porting model files is that the new model may not have the same set of switces as the old one. In order to help people wanting to port a model file to a model they don't have, I've provided a list of switches here, listing the tx's in numerical order. | + | The one serious issue when porting model files is that the new model may not have the same set of switches as the old one. In order to help people wanting to port a model file to a model they don't have, I've provided a list of switches here, listing the tx's in numerical order. |
- | * **Stock**: DR0, DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2 | + | * **Stock**: \\ DR0, DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2 |
- | * **Modded**((There are published hardware mods for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. These are supported by the latest nightly builds)): SW A0, SW A1, SW A2, SW B0, SW B1 | + | * **Modded**((There are [[http://www.rcgroups.com/forums/showthread.php?t=2536181|published hardware mods]] for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. Additionally two pairs of Trims can be added using existing through holes. These are supported in 5.0 and later. Adding both switches and trims brings the number of inputs on the 6/6S to the same level as the 8/8S/10/F12E)): \\ (SW A0, SW A1, SW A2) or (SW A0, SW A1, SW B0, SW B1) |
- | * **Stock**: HOLD0, HOLD1, FMOD0, FMOD1 | + | * **Stock**: \\ HOLD0, HOLD1, FMOD0, FMOD1 |
- | * **Modded**((There are published hardware modes for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported by the latest nightly builds)): SW A0, SW A1, SW A2, SW B0, SW B1, SW B2 | + | * **Modded**((There are [[http://www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e?start=180|published hardware mods]] for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported in 5.0 and later)): \\ SW A0, SW A1, SW A2, SW B0, SW B1, SW B2 |
- | * **Devo8** and **Devo10** and **Devo F12E**: RUD DR0, RUD DR1, ELE DR0, ELE DR1, AIL DR0, AIL DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2 | + | |
- | * **Devo12**: RUD DR0, RUD DR1, RUD DR2, ELE DR0, ELE DR1, ELE DR2, AIL DR0, AIL DR1, AIL DR2, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2, HOLD0, HOLD1, TRN0, TRN1 | + | * **Devo8** and **Devo10** and **Devo F12E**: |
- | * **Devo F7**: AIL_DR0, AIL_DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2 | + | * **Stock**: \\ RUD DR0, RUD DR1, ELE DR0, ELE DR1, AIL DR0, AIL DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2 |
+ | * **Devo12**: | ||
+ | * **Devo F7**: | ||
+ | * **Devo F4**: | ||
transmiterswitches.txt (123165 views) · Last modified: 2017/05/21 12:03 by mwm
