transmiterswitches
transmiterswitches [2016/06/12 15:52] mwm Note that switch mods on 6/7e are in 5.0 |
- | * **Modded**((There are published hardware mods for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. Additionally two pairs of Trims can be added using existing through holes. These are supported in 5.0 and later. Adding both switches and trims brings the number of inputs on the 6/6S to the same level as the 8/8S/10/F12E)): \\ (SW A0, SW A1, SW A2) or (SW A0, SW A1, SW B0, SW B1) | + | * **Modded**((There are [[http://www.rcgroups.com/forums/showthread.php?t=2536181|published hardware mods]] for the 6 and 6s to add either two 2-way switches or a 3-way switch just by connecting the switches to the existing through holes. Additionally two pairs of Trims can be added using existing through holes. These are supported in 5.0 and later. Adding both switches and trims brings the number of inputs on the 6/6S to the same level as the 8/8S/10/F12E)): \\ (SW A0, SW A1, SW A2) or (SW A0, SW A1, SW B0, SW B1) |
- | * **Modded**((There are published hardware modes for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported in 5.0 and later)): \\ SW A0, SW A1, SW A2, SW B0, SW B1, SW B2 | + | * **Modded**((There are [[https://www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e?start=180|published hardware mods]] for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported in 5.0 and later)): \\ SW A0, SW A1, SW A2, SW B0, SW B1, SW B2 |
+ | * **Devo F4**: | ||
transmiterswitches.1465771937.txt.gz (121490 views) · Last modified: 2016/06/12 15:52 by mwm
