transmiterswitches
transmiterswitches [2016/07/03 23:39]
FDR
transmiterswitches [2017/05/21 12:03] (current)
mwm
Line 1: Line 1:
 ===== Devo transmitter switches ===== ===== Devo transmitter switches =====
-The one serious issue when porting model files is that the new model may not have the same set of switches as the old one. In order to help people wanting to port a model file to model they don't have, I've provided a list of switches here, listing the tx's in numerical order.+The one serious issue when porting model files is that the new transmitter ​may not have the same set of switches as the old one. In order to help people wanting to port a model file fram transmitter ​they don't have, I've provided a list of switches here, listing the tx's in numerical order.
 ==== Switches available ==== ==== Switches available ====
Line 9: Line 9:
   * **Devo7e**:   * **Devo7e**:
      * **Stock**: \\ HOLD0, HOLD1, FMOD0, FMOD1      * **Stock**: \\ HOLD0, HOLD1, FMOD0, FMOD1
-     * **Modded**((There are published hardware ​modes for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported in 5.0 and later)): \\ SW A0, SW A1, SW A2, SW B0, SW B1, SW B2+     * **Modded**((There are [[https://​www.deviationtx.com/​forum/​how-to/​1436-add-two-switches-to-the-devo-7e?​start=180|published hardware ​mods]] ​for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported in 5.0 and later)): \\ SW A0, SW A1, SW A2, SW B0, SW B1, SW B2
-  *  **Devo8** and **Devo10** and **Devo F12E**: \\ RUD DR0, RUD DR1, ELE DR0, ELE DR1, AIL DR0, AIL DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2+  *  **Devo8** and **Devo10** and **Devo F12E**:
 +     * **Stock**: \\ RUD DR0, RUD DR1, ELE DR0, ELE DR1, AIL DR0, AIL DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2
-  * **Devo12**: \\ RUD DR0, RUD DR1, RUD DR2, ELE DR0, ELE DR1, ELE DR2, AIL DR0, AIL DR1, AIL DR2, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2, HOLD0, HOLD1, TRN0, TRN1+  * **Devo12**:
 +     * **Stock**: \\ RUD DR0, RUD DR1, RUD DR2, ELE DR0, ELE DR1, ELE DR2, AIL DR0, AIL DR1, AIL DR2, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2, HOLD0, HOLD1, TRN0, TRN1
-  * **Devo F7**: \\ AIL_DR0, AIL_DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2+  * **Devo F7**:
 +     * **Stock**: \\ AIL_DR0, AIL_DR1, GEAR0, GEAR1, MIX0, MIX1, MIX2, FMOD0, FMOD1, FMOD2
 +  * **Devo F4**:
 +     * **Stock**: \\ The Devo F4 has no switches at all.
 ==== Virtual switches ==== ==== Virtual switches ====
-The lack of switches on the Devo7e and Devo6 can be dealt with by using the *Trim as Virtual Switch*. See the manual for details on how to set those up. Using the throttle trim switches as a pair works well, and the buttons beside the LCD can be used as push-button switches.+The lack of switches on the Devo F4, Devo F7, Devo7e and Devo6 can be dealt with by using the *Trim as Virtual Switch*. See the manual for details on how to set those up. Using the throttle trim switches as a pair works well, and the buttons beside the LCD can be used as push-button switches.
 ==== Other inputs ==== ==== Other inputs ====
 In addition, the Devo 10, 12, and F12E have extra analog inputs. The 10 has AUX4 and AUX6, the 12 has AUX2-AUX6, and the F12E has AUX4-AUX7. In addition, the Devo 10, 12, and F12E have extra analog inputs. The 10 has AUX4 and AUX6, the 12 has AUX2-AUX6, and the F12E has AUX4-AUX7.
transmiterswitches.1467614359.txt.gz (6953 views) · Last modified: 2016/07/03 23:39 by FDR
