transmitter:devo6
transmitter:devo6 [2016/05/13 16:06] Deal57 [Hardware Information] Updates for Devo 6 |
transmitter:devo6 [2016/05/13 16:09] Deal57 [Hardware Information] |
Line 81: | Line 81: | ||
- | *[[hardware:devo8|Devo 8 Hardware & Connections]] | + | |
- | Note that the Devo 6 has been found to have essentially the same hardware and connections as the Devo 8; until a specific Devo 6 Hardware page is made, refer to the Devo 8 hardware. | + | Note that the Devo 6 has been found to have essentially the same hardware and connections as the Devo 8. The trim matrix used is the same, although the Top Right and Top Left trim buttons are not installed. The switches use a different order of the same pins. |
*[[hardware:devo6|Devo 6 Hardware & Connections]] | *[[hardware:devo6|Devo 6 Hardware & Connections]] |
transmitter/devo6.txt (47548 views) · Last modified: 2017/01/23 00:40 by FDR
