transmitter:devo7e
transmitter:devo7e [2016/05/08 08:23] silpstream created |
transmitter:devo7e [2016/05/08 13:11] silpstream Fix links |
+ | ~~TOC:3-6~~ | ||
Line 6: | Line 7: | ||
- | ==== Features ==== | + | SeBy DocKy has made a great series of tutorial videos for the Devo 7E. Here is his [[https://youtu.be/7hvjtHtRFXg?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|introduction to the Devo 7E]]. |
+ | ^ Features || | ||
Line 19: | Line 22: | ||
- | ==== Modifications ==== | + | ---- |
- | Due to its' popularity, the Devo 7E probably has the most documented modifications available within the Walkera Devo line of transmitters. Here you'll find the tutorials and videos to get you started. | + | |
+ | === Installing DeviationTx === | ||
+ | Start by reading the Devo 7E [[http://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | ||
+ | *[[https://youtu.be/2oqwpJJWssw?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part2 - deviationTX installation]] by SeBy DocKy | ||
+ | === Modifications === | ||
+ | Due to its' popularity and price, the Devo 7E probably has the most documented modifications available within the Walkera Devo line of transmitters. Here you'll find the tutorials and videos to get you started. | ||
+ | Alternatively you can [[:building_the_multi-module|build]] the [[:multimod|MultiModule]] instead. With the MultiModule, you will not need to solder to the processor pin and still use all 4 modules. | ||
+ | *[[http://www.hacksmods.com/2013/04/walkera-devo-7e-transmitter-deviationx-flysky-hubsan-mod/|Walkera Devo 7E TransmitterDeviationTx Flysky/Hubsan Mod]] by hacksmods.com | ||
+ | *[[https://youtu.be/u1SPgG2vWiE?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part7 - nRF24L01 mod]] by SeBy DocKy | ||
+ | *[[https://youtu.be/0oXjk_oQsE8?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part8 - CC2500 mod]] by SeBy DocKy | ||
Line 40: | Line 63: | ||
- | == Add a Power-on LED == | + | == Add Power-on LEDs == |
+ | == USB Charge Mod == | ||
+ | === Other Devo 7E Resources === | ||
+ | === Hardware Information === | ||
+ | *[[hardware:devo7e|Devo 7E Hardware & Connections]] | ||
transmitter/devo7e.txt (2790 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
