transmitter:devo7e
transmitter:devo7e [2016/05/08 08:23] silpstream created |
transmitter:devo7e [2016/05/08 22:14] silpstream fix links |
+ | ~~TOC:3-6~~ | ||
Line 6: | Line 7: | ||
- | ==== Features ==== | + | SeBy DocKy has made a great series of tutorial videos for the Devo 7E. Here is his [[https://youtu.be/7hvjtHtRFXg?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|introduction to the Devo 7E]]. |
+ | ^ Features || | ||
Line 18: | Line 21: | ||
^ USB Upgradable | Yes | | ^ USB Upgradable | Yes | | ||
+ | ==== Installing DeviationTx ==== | ||
+ | Start by reading the Devo 7E [[http://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | ||
+ | *[[https://youtu.be/2oqwpJJWssw?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part2 - deviationTX installation]] by SeBy DocKy | ||
+ | *[[http://www.hacksmods.com/2013/04/walkera-devo-7e-transmitter-deviationx-flysky-hubsan-mod/|Walkera Devo 7E TransmitterDeviationTx Flysky/Hubsan Mod]] by hacksmods.com | ||
+ | *[[https://youtu.be/u1SPgG2vWiE?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part7 - nRF24L01 mod]] by SeBy DocKy | ||
+ | *[[https://youtu.be/0oXjk_oQsE8?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part8 - CC2500 mod]] by SeBy DocKy | ||
+ | This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode (or resistor?) within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try. | ||
+ | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] on our fourm | ||
Line 40: | Line 72: | ||
- | == Add a Power-on LED == | + | == Add Power-on LEDs == |
+ | == USB Charge Mod == | ||
+ | *[[hardware:devo7e|Devo 7E Hardware & Connections]] | ||
transmitter/devo7e.txt (88417 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
