transmitter:devo7e
transmitter:devo7e [2016/05/08 08:24] silpstream |
transmitter:devo7e [2016/05/09 08:16] silpstream |
- | ==== Features ==== | + | *[[https://youtu.be/7hvjtHtRFXg?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Introduction to the Devo 7E]] by SeBy DocKy |
+ | ^ Features || | ||
Line 19: | Line 23: | ||
^ USB Upgradable | Yes | | ^ USB Upgradable | Yes | | ||
+ | ==== Installing DeviationTx ==== | ||
+ | Start by reading the Devo 7E [[http://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | ||
+ | *[[https://youtu.be/2oqwpJJWssw?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|DeviationTX Installation]] by SeBy DocKy | ||
+ | == Disassembly == | ||
+ | *[[http://www.hacksmods.com/2013/04/walkera-devo-7e-transmitter-deviationx-flysky-hubsan-mod/|Devo 7E DeviationTx Flysky/Hubsan Mod]] by hacksmods.com | ||
+ | *[[https://youtu.be/u1SPgG2vWiE?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E nRF24L01 mod]] by SeBy DocKy | ||
+ | *[[https://youtu.be/0oXjk_oQsE8?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E CC2500 mod]] by SeBy DocKy | ||
+ | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] by Mullson in our forum | ||
+ | *[[http://www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e|Add Two switches to the Devo 7E]] by cmpang in our forum | ||
+ | *[[http://www.deviationtx.com/forum/7-development/4442-extra-inputs-for-devo-tx-s?limitstart=0|Extra inputs for Devo Tx's]] by mwm in our forum | ||
+ | *[[http://www.deviationtx.com/forum/how-to/1455-battery-mod-devo7e|Battery Mod Devo 7E]] by Usjak in our forum | ||
+ | *[[http://www.deviationtx.com/forum/6-general-discussions/2910-devo-7e-a7105pa-range-mod-current-draw?start=20#24372|AMS1117 Replacement Regulator]] by Fernandez in our forum | ||
+ | *[[http://www.deviationtx.com/forum/6-general-discussions/5307-problem-with-overvolted-devo7e#43231|Pololu 3.3V Step-Up/Step-Down Voltage Regulator]] by Fernandez in our forum | ||
+ | == Add Power-on LEDs == | ||
+ | == USB Charge Mod == | ||
+ | *[[hardware:devo7e|Devo 7E Hardware & Connections]] | ||
- | == Add a Power-on LED == |
transmitter/devo7e.txt (84684 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
