transmitter:devo7e
transmitter:devo7e [2016/05/08 13:09] silpstream Add info |
transmitter:devo7e [2016/05/08 22:14] silpstream fix links |
Line 24: | Line 24: | ||
Start by reading the Devo 7E [[http://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | Start by reading the Devo 7E [[http://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | ||
Line 32: | Line 32: | ||
Line 38: | Line 40: | ||
- | Alternatively you can [[building_the_multi-module|build]] the [[multimod|MultiModule]] instead. With the MultiModule, you will not need to solder to the processor pin and still use all 4 modules. | + | Alternatively you can [[:building_the_multi-module|build]] the [[modulelist:multimod|MultiModule]] instead. With the MultiModule, you will not need to solder to the processor pin and still use all 4 modules. |
- | The process is very well documented in the wiki page "[[rf_module_installation|RF Module Installation]]". | + | The process is very well documented in the wiki page "[[:rf_module_installation|RF Module Installation]]". |
Line 48: | Line 50: | ||
+ | This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode (or resistor?) within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try. | ||
+ | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] on our fourm | ||
Line 68: | Line 77: | ||
- | === Other Devo 7E Resources === | + | ---- |
Line 75: | Line 86: | ||
transmitter/devo7e.txt (86574 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
