transmitter:devo7e
transmitter:devo7e [2016/05/08 13:11] silpstream Fix links |
transmitter:devo7e [2016/06/02 01:12] silpstream add link to 4-in-1 |
Line 24: | Line 26: | ||
Start by reading the Devo 7E [[http://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | Start by reading the Devo 7E [[http://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | ||
+ | == Disassembly == | ||
- | Alternatively you can [[:building_the_multi-module|build]] the [[:multimod|MultiModule]] instead. With the MultiModule, you will not need to solder to the processor pin and still use all 4 modules. | + | Alternatively you can [[:building_the_multi-module|build]] the [[modulelist:multimod|MultiModule]] instead. With the MultiModule, you will not need to solder to the processor pin and still use all 4 modules. |
The process is very well documented in the wiki page "[[:rf_module_installation|RF Module Installation]]". | The process is very well documented in the wiki page "[[:rf_module_installation|RF Module Installation]]". | ||
+ | *[[http://www.deviationtx.com/forum/how-to/5955-7e-ultimate7e-adding-the-devo-version-4in1|7e/Ultimate7e, adding the devo version 4in1]] by HappyHarry in our forum | ||
+ | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] by Mullson in our forum | ||
+ | *[[http://www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e|Add Two switches to the Devo 7E]] by cmpang in our forum | ||
+ | *[[http://www.deviationtx.com/forum/7-development/4442-extra-inputs-for-devo-tx-s?limitstart=0|Extra inputs for Devo Tx's]] by mwm in our forum | ||
+ | *[[http://www.deviationtx.com/forum/how-to/1455-battery-mod-devo7e|Battery Mod Devo 7E]] by Usjak in our forum | ||
+ | *[[http://www.deviationtx.com/forum/6-general-discussions/2910-devo-7e-a7105pa-range-mod-current-draw?start=20#24372|AMS1117 Replacement Regulator]] by Fernandez in our forum | ||
+ | *[[http://www.deviationtx.com/forum/6-general-discussions/5307-problem-with-overvolted-devo7e#43231|Pololu 3.3V Step-Up/Step-Down Voltage Regulator]] by Fernandez in our forum | ||
Line 75: | Line 126: | ||
- | *[[hardware:devo7e|Devo 7E Hardware & Connections]] | + | |
transmitter/devo7e.txt (85361 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
