transmitter:devo7e
transmitter:devo7e [2016/05/08 22:14] silpstream fix links |
transmitter:devo7e [2019/02/22 15:39] PhracturedBlue |
Line 25: | Line 27: | ||
==== Installing DeviationTx ==== | ==== Installing DeviationTx ==== | ||
Line 36: | Line 38: | ||
+ | == Disassembly == | ||
Line 45: | Line 55: | ||
- | This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode (or resistor?) within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try. | + | This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try. |
- | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] on our fourm | + | *[[https://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] by Mullson in our forum |
Line 61: | Line 72: | ||
==== Other Devo 7E Resources ==== | ==== Other Devo 7E Resources ==== | ||
Line 90: | Line 133: | ||
transmitter/devo7e.txt (85362 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
