transmitter:devo7e
transmitter:devo7e [2016/05/09 02:05] silpstream Add content |
transmitter:devo7e [2016/05/09 07:45] silpstream |
Line 62: | Line 62: | ||
This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try. | This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try. | ||
- | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] in our forum | + | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] by Mullson in our forum |
Line 72: | Line 72: | ||
This modification will add two 2-way switches labeled "SW A" and "SW B". | This modification will add two 2-way switches labeled "SW A" and "SW B". | ||
+ | *[[http://www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e|Add Two switches to the Devo 7E]] by cmpang in our forum | ||
This modification will add either one or two 2-way switches labeled "SW A" or "SW A" and "SW B" respectively. | This modification will add either one or two 2-way switches labeled "SW A" or "SW A" and "SW B" respectively. | ||
Line 83: | Line 86: | ||
*[[https://youtu.be/xYJ8d11NmgQ|Devo 7E Antenna Mod]] by Iurii Merdok | *[[https://youtu.be/xYJ8d11NmgQ|Devo 7E Antenna Mod]] by Iurii Merdok | ||
*[[https://youtu.be/cDcr3iFtqvo|CYRF6936 Antenna Mod]] by SeBy DocKy | *[[https://youtu.be/cDcr3iFtqvo|CYRF6936 Antenna Mod]] by SeBy DocKy | ||
- | Swap out to a higher capacity LiPo battery | + | Swap out to a higher capacity LiPo battery. Search around as there are now few manufacturers that make a LiPo specifically for the Devo 7E. |
+ | *[[http://www.deviationtx.com/forum/how-to/1455-battery-mod-devo7e|Battery Mod Devo 7E]] by Usjak in our forum | ||
Adding higher power handling regulators for the extra load due to the RF module upgrades. | Adding higher power handling regulators for the extra load due to the RF module upgrades. | ||
Have an LED light up when the power is turned on. | Have an LED light up when the power is turned on. |
transmitter/devo7e.txt (84574 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
