transmitter:devo7e
transmitter:devo7e [2016/05/08 22:14]
silpstream fix links
transmitter:devo7e [2019/02/22 15:39] (current)
PhracturedBlue
Line 7: Line 7:
 It however only has 128k of flash memory, which is barely sufficient for DeviationTx. It is equipped with only two 2-way switches and a range limited RF module. There are proven modification though to overcome these limitations. It however only has 128k of flash memory, which is barely sufficient for DeviationTx. It is equipped with only two 2-way switches and a range limited RF module. There are proven modification though to overcome these limitations.
-SeBy DocKy has made a great series of tutorial videos for the Devo 7E. Here is his [[https://​youtu.be/​7hvjtHtRFXg?​list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|introduction ​to the Devo 7E]].+  *[[https://​youtu.be/​7hvjtHtRFXg?​list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Introduction ​to the Devo 7E]] by SeBy DocKy
 +  *[[https://​youtu.be/​OcVRESGMvxw|Walkera Devo 7E transmitter with Deviation review]] by kenVersus
 +  *[[https://​youtu.be/​oig14GSumVA|Control All Models With One Transmitter - Deviationtx]] by AndyRC
 ^ Features || ^ Features ||
Line 25: Line 27:
 ==== Installing DeviationTx ==== ==== Installing DeviationTx ====
-Start by reading the Devo 7E [[http://​www.deviationtx.com/​user-manual/​user-manual-7e-10|manual]].+Start by reading the Devo 7E [[https://​www.deviationtx.com/​user-manual/​user-manual-7e-10|manual]].
 If that's not enough, the tutorials below should get you going. If that's not enough, the tutorials below should get you going.
   *[[https://​youtu.be/​cj36KytnsQo|HowTo:​ Install DEVIATION on a Walkera Devo 7e]] by RCFanBlog   *[[https://​youtu.be/​cj36KytnsQo|HowTo:​ Install DEVIATION on a Walkera Devo 7e]] by RCFanBlog
-  *[[https://​youtu.be/​2oqwpJJWssw?​list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E tutorials: part2 - deviationTX installation]] by SeBy DocKy+  *[[https://​youtu.be/​2oqwpJJWssw?​list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|DeviationTX Installation]] by SeBy DocKy
   *[[http://​benmlee.com/​Deviation_Install.html|Install Deviation Hack on DEVO Radio]] by benmlee.com   *[[http://​benmlee.com/​Deviation_Install.html|Install Deviation Hack on DEVO Radio]] by benmlee.com
Line 36: Line 38:
 ==== Modifications ==== ==== Modifications ====
 Due to its' popularity and price, the Devo 7E probably has the most documented modifications available within the Walkera Devo line of transmitters. Here you'll find the tutorials and videos to get you started. Due to its' popularity and price, the Devo 7E probably has the most documented modifications available within the Walkera Devo line of transmitters. Here you'll find the tutorials and videos to get you started.
 +== Disassembly ==
 +All modifications have to begin with disassembling the transmitter. Here's how to do it.
 +{{:​hardware:​devo7e:​devo7e_disassemble.png?​nolink&​680}}
 +  *[[https://​youtu.be/​-ed1-kYh3k0?​list=PLkh_SGqn4zvgPR5_WgztE-SPM-t6smX91|Opening Devo 7E]] by jygravityRC
 +  *[[https://​youtu.be/​T9tKSoFqAcY?​list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo 7E Disassembling]] by SeBy DocKy
 == Extra RF Modules == == Extra RF Modules ==
Line 45: Line 55:
 Additional information can be found here: Additional information can be found here:
-  *[[http://​www.hacksmods.com/​2013/​04/​walkera-devo-7e-transmitter-deviationx-flysky-hubsan-mod/​|Walkera ​Devo 7E TransmitterDeviationTx ​Flysky/​Hubsan Mod]] by hacksmods.com +  *[[http://​www.hacksmods.com/​2013/​04/​walkera-devo-7e-transmitter-deviationx-flysky-hubsan-mod/​|Devo 7E DeviationTx ​Flysky/​Hubsan Mod]] by hacksmods.com
-  *[[https://​youtu.be/​u1SPgG2vWiE?​list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E ​tutorials: part7 - nRF24L01 mod]] by SeBy DocKy +  *[[https://​youtu.be/​u1SPgG2vWiE?​list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E nRF24L01 mod]] by SeBy DocKy
-  *[[https://​youtu.be/​0oXjk_oQsE8?​list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E ​tutorials: part8 - CC2500 mod]] by SeBy DocKy+  *[[https://​youtu.be/​0oXjk_oQsE8?​list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E CC2500 mod]] by SeBy DocKy
 +  *[[https://​www.deviationtx.com/​forum/​how-to/​5955-7e-ultimate7e-adding-the-devo-version-4in1|7e/​Ultimate7e,​ adding the devo version 4in1]] by HappyHarry in our forum
 == Full Range Mod == == Full Range Mod ==
-This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode (or resistor?​) ​within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try.+This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try.
   *[[http://​www.hacksmods.com/​2013/​04/​walkera-devo-7e-transmitter-increase-range-mod/​|Walkera Devo 7e Transmitter Increase Range Mod]] by hacksmods.com   *[[http://​www.hacksmods.com/​2013/​04/​walkera-devo-7e-transmitter-increase-range-mod/​|Walkera Devo 7e Transmitter Increase Range Mod]] by hacksmods.com
-  *[[http://​www.deviationtx.com/​forum/​3-feedback-questions/​1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] ​on our fourm+  *[[https://​www.deviationtx.com/​forum/​3-feedback-questions/​1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] ​by Mullson in our forum
   *[[https://​youtu.be/​tdko3ZR7AWI|Devo7E tutorials: part4 - CYRF6936 diode mod]] by SeBy DocKy   *[[https://​youtu.be/​tdko3ZR7AWI|Devo7E tutorials: part4 - CYRF6936 diode mod]] by SeBy DocKy
   *[[http://​community.micro-motor-warehouse.com/​t/​devo-7e-range-mod/​1691|Devo 7e range mod]] by jayodas   *[[http://​community.micro-motor-warehouse.com/​t/​devo-7e-range-mod/​1691|Devo 7e range mod]] by jayodas
Line 61: Line 72:
 == Add Two 2-way Switches == == Add Two 2-way Switches ==
 +This modification will add two 2-way switches labeled "SW A" and "SW B".
 +  *[[https://​www.deviationtx.com/​forum/​how-to/​1436-add-two-switches-to-the-devo-7e|Add Two switches to the Devo 7E]] by cmpang in our forum
 == Add One/Two 3-way Switches == == Add One/Two 3-way Switches ==
 +This modification will add either one or two 2-way switches labeled "SW A" or "SW A" and "SW B" respectively.
 +  *[[http://​www.rcgroups.com/​forums/​showthread.php?​t=2468549|Adding Two 3-position Switches]] by straferr on rcgroups.com
 +  *[[https://​youtu.be/​IKif67S_pzs|3x2 Switches Mod]] by SeBy DocKy
 +== Add Upto 4 3-way or 8 2-way (or any combination thereof) Switches ==
 +*[[https://​www.deviationtx.com/​forum/​how-to/​5824-ultimate7e-tutorial-four-3-way-two-2-way-switch?​screenMode=desktop&​start=40#​50865|3x4,​ 2x8 Switches]] by slipstream
 == Arduino to PPMin for Extra Inputs == == Arduino to PPMin for Extra Inputs ==
 +The trainer port can be hijacked for an arduino to provide PPM signals from nearly any combination of switches and potentiometers. This modification effectively takes over the trainer port by mimicking a 2nd connected transmitter and injects PPM signal to the channels. Note that once you do this mod, you will not be able to connect another transmitter to the trainer port.
 +  *[[http://​www.rcgroups.com/​forums/​showthread.php?​t=2481981|Extra Potentiometer and Switch Inputs for Devo TX]] by JW57RC on rcgroups.com
 +  *[[https://​www.deviationtx.com/​forum/​7-development/​4442-extra-inputs-for-devo-tx-s?​limitstart=0|Extra inputs for Devo Tx's]] by mwm in our forum
 == Swivel Antenna Mod == == Swivel Antenna Mod ==
 +Install an external swappable swivel antenna to improve reception and reliability.
 +  *[[https://​youtu.be/​xYJ8d11NmgQ|Devo 7E Antenna Mod]] by Iurii Merdok
 +  *[[https://​youtu.be/​cDcr3iFtqvo|CYRF6936 Antenna Mod]] by SeBy DocKy
 +  *[[http://​www.hacksmods.com/​2014/​10/​devo-7e-swivel-antenna-mod/​|Devo 7E Swivel Antenna Mod]] by hacksmods.com
 == LiPo Battery Mod == == LiPo Battery Mod ==
 +Swap out to a higher capacity LiPo battery. Search around as there are now few manufacturers that make a LiPo specifically for the Devo 7E.
 +  *[[http://​www.rcgroups.com/​forums/​showpost.php?​p=28700856&​postcount=3|Turnigy nano-tech in Devo 7E]] by Fyathyrio on rcgroups.com
 +  *[[https://​www.deviationtx.com/​forum/​how-to/​1455-battery-mod-devo7e|Battery Mod Devo 7E]] by Usjak in our forum
 == Power Regulator Upgrade == == Power Regulator Upgrade ==
 +Adding higher power handling regulators for the extra load due to the RF module upgrades.
 +  *[[https://​www.deviationtx.com/​forum/​6-general-discussions/​2910-devo-7e-a7105pa-range-mod-current-draw?​start=20#​24372|AMS1117 Replacement Regulator]] by Fernandez in our forum
 +  *[[https://​www.deviationtx.com/​forum/​6-general-discussions/​5307-problem-with-overvolted-devo7e#​43231|Pololu 3.3V Step-Up/​Step-Down Voltage Regulator]] by Fernandez in our forum
 == Add Power-on LEDs == == Add Power-on LEDs ==
 +Have an LED light up when the power is turned on.
 +  *[[http://​www.rcgroups.com/​forums/​showthread.php?​t=1918045&​highlight=LED&​page=216|Not really any tutorials, but lots of hints]] on rcgroups.com
 == USB Charge Mod == == USB Charge Mod ==
 +Enable power in from the USB port.
   *[[http://​community.micro-motor-warehouse.com/​t/​devo-7e-usb-charge-mod/​943|Devo 7e USB charge mod]] by KewlbasaDawg   *[[http://​community.micro-motor-warehouse.com/​t/​devo-7e-usb-charge-mod/​943|Devo 7e USB charge mod]] by KewlbasaDawg
 +== 3D Printable Parts ==
 +These are some parts that can be 3D printed to upgrade the Devo 7E.
 +  *[[http://​www.thingiverse.com/​thing:​641114|Devo 7E Main and Second Antenna Base]] by Sakunamary
 +  *[[http://​www.thingiverse.com/​thing:​989564|Devo 7E FPV Monitor/​RX/​Battery Mount]] by HLMAX
 +  *[[http://​www.thingiverse.com/​thing:​989552|Devo 7E Antenna Mount]] by HLMAX
 +  *[[http://​www.thingiverse.com/​thing:​1170945|Devo 7E Antenna Mast]] by anansi22
 ==== Other Devo 7E Resources ==== ==== Other Devo 7E Resources ====
 +  *[[http://​www.rcgroups.com/​forums/​showthread.php?​t=1693112|New Devo 7E Radio from Walkera]] on rcgroups.com
   *[[http://​www.drone-maniac.com/​diy-devo-7e-tutorials/​|DIY:​ DEVO 7E TUTORIALS]]   *[[http://​www.drone-maniac.com/​diy-devo-7e-tutorials/​|DIY:​ DEVO 7E TUTORIALS]]
   *[[http://​www.hacksmods.com/​tag/​devo7e/​|Devo 7E on hacksmods.com]]   *[[http://​www.hacksmods.com/​tag/​devo7e/​|Devo 7E on hacksmods.com]]
Line 90: Line 133:
 ==== Hardware Information ==== ==== Hardware Information ====
   *[[hardware:​devo7e|Devo 7E Hardware & Connections]]   *[[hardware:​devo7e|Devo 7E Hardware & Connections]]
transmitter/devo7e.1462770849.txt.gz (83503 views) · Last modified: 2016/05/08 22:14 by silpstream
